Not much cheap about it. But.....Given what I have OTHERWISE had to spend to connect a nominal 10 KW (at 8,000 ft AMSL), actual 12 KW, peak 15 KW "tactically quiet" NATO-spec MEP-803a Diesel gen set?
The cost for the RPC and P-P distribution was more in (recycled) Square-D switchgear, 3-P lock-out-able rotary disconnects, a good grade of twist-lock outlets and heavy SO cordsets by far than in the basic distribution wire, load center to RPC, or RPC to 3-P mini-panel.
Mind - tight space, small shop of but approx 1200 SF and less than 2:1 aspect ratio - nearly square IOW - means relatively short WIRE runs here, but just as many boxes, protective devices, disconnects, cordsets, and connectors as a larger space, similar "consumer machine" count.
"Page Two" will see the RPC exiled to a back-yard shed location alongside the Diesel, so I'll be reliant on indicator lamps to even know it is whirring. Gen set is 3-P capable, BTW, so part of the wire and conduit run can be "borrowed" when mains power is available and gen set is offline.
The Phase-Perfects need friendlier year-round temps than an RPC. Those will stay indoors, just migrate into an adjacent space to better isolate them from the chip and dust making area than at present.
One other thing... "eventually", I - or my Widow/Estate - will need to sell this house.
"We craftsman" seldom think of it, but for the general real-estate market, "shop equipped" is a negative to more potential buyers than it is a positive.
Accordingly, all of this is being done with surface-mount duct or conduit and SO cordsets in a manner with a specific eye towrd ease of removal. IOW. NONE of it neatly buried in-wall as the normal residential electrical services are - not even the 230 VAC 1-P outlets.
The RPC is even meant to migrate from hand-truck/ furniture-dolly portable to its own permanent wheeled mount.
May or may not do the P-P the same way. They don't NEED that, but wuddn' yah know it? Daggone gravity seems to get stronger as I grow older! Go figure.
Most things in a space this small benefit from permanent skates or such that let me sort of "garage" a machine not in current use or frequent use. The shaper, pantoengraver, smaller mill and drillpress, for example.
2CW, Your space and environment, mileage may vary.
PS: I said "Office Depot" expanded mesh wastebasket. One end is actually a re-purposed rectangular hanging file-folder box. These are wire framed, expanded metal goods that DENT if looked at crosswise, so showed up at closeout prices.
I can sort a dent way faster than I can fab such goods from scratch, so grabbed 'em cheaply when I could. A bit of copmmon galvanized sheet steel does the rest.
Fotos oafter I deal with a failing over-age-in-grade and badly wind-damaged
roof over the whole shebang...
