Not a lot of knowledge in this area, just looking for a little help to get pointed in the right direction. No need to go negative.
That's POSITIVE, Pilgrim.
If I thought you were unable to learn, grow, and make USE of information? I'd simply ignore you outright.
Let's get better sight of your needs, here. Pretend it is a clean sheet design so we can see if the answers come out close to what has already been done, if not, why not, and if so, HOW close.
Not as if PM community were
charging you for that assistance, is it?
Or do you wish to risk your THIRD motor choice being even less appropriate than the SECOND one? Motor MAKER was supposed to be the go-to for expertise. But they f**ked up.
Now you need to check their work. Give them stricter goals. Or replace them.
So...
What specs and "type" are on the old motor and new, how much torque or HP needed, what are you asking it to DO duty-cycle and loading-wise, how much space and heat-rise budget do you have, what severe challenges as to wet/dry, dirty/abrasive, special shape or mounting?.... etc.
Very little is so "new" that some OTHER situations have not already provided experience.
They do not "match up" automagically without looking for those matches, though.
Far too many possible types, sizes, options in general.
