Don Gitzel
- Jul 25, 2017
Hello !! First post but have been lurking around for awhile. My question is hooking up a three phase step up transformer to a rotary phase converter. 230 1 ph to 600 3 ph. I have assembled many phase converters over the years and have found you cannot perfectly balance the phases. The generated phase always draws less amperage. Also the voltage to ground of this phase is double of the normal phases. With a Y - Delta Xmer you would think this would be a problem. The centre point of the Y primary is bonded to ground. I spoke to a chap from Cedarburg and he spoke of a second transformer to adjust the generated leg but he lost me. Thanks in advance if anyone can enlighten me on this subject. I do know that one solution is to use a single phase Xmer before the converter but once you start buying 600 volt capacitors it gets expensive.
