saintscustomwork
- Aug 9, 2011
- Church Hill TN
I need some help if there is any help possible. I purchased a dpc20 on eBay from a machine reseller that was untested as is. I receive it in well packed very clean condition( not so clean that it looked suspicious).. I pulled the covers and gave everything thing a once over, looking for noticeable damage or disrepair. All looked good. Wired it and checked my voltage before I flipped the breaker. Getting 120v to each leg and 240v across. Good so far. Crossed my fingers and flipped the breaker. Nothing for several seconds then fans kick on. Check input voltage still 120v,120v, checked t1 120v, t2 120v, t3 nothing. Little red led blinking. Red only. Check online and it says internal short. Contacted phase technology and the sent a trouble shooting guide. Guide says problem with IGBT’s or the drivers of the IGBT’s on the control board. I contacted phase technology again and asked what to check and where the igbt’s are located(I found them) they said the dpc series is no longer supported and could offer no technical support..
Has anyone had this issue? Any help and guidance would be greatly appreciated. I’m not an electrical wiz but I can read, research, and figure things out. Just need a direction to move
