While I'm moving into the new shop I decided its time I take a look inside these.
Seems quite a few of us have these units, but do any of us really do the capacitor maintenance on them? I've not noticed it ever really being talked about on here, part of why I started this thread(I'll also email PP about getting new capacitors). Is there anything else we should look at(other than dust/arcing/hot wires) ?
I have a blue, DPC-A10 (10hp, bought around 2007-2008 I think) used pretty near every day since probably around 30k/hrs On time, and a newer PT-355(20hp), maybe 4-5yrs old but only a few hundreds hours on that one.
I never did anything to either one yet. I'm surprised how clean the inside of the 10HP unit still is considering it was under the bench I do my grinding/sanding on, still look brand new and no dust in there. Manual says there's Line Filter capacitors that should be changed every 3yrs and inspected more regularly. I see no bulge or anything on any of these in either unit, but its probably time to change them anyway eh?
Slight trouble is its pretty cramped in there, do you guys have any trick to doing this if you're changed them? can't just pop them out, wires and things in the way on the 10HP unit, 20hp looks a tiny bit easier but they're still a ways in there to reach at.
On the 10hp unit I also noticed 4 other black plastic shell canisters that look like big capacitors as well(I can't see a sticker for what they are/rating, probably 3x the size of the little metal ones) what's the deal with those things, are they capacitors too? no need to replace? (pictures coming)
One thing I noticed on the 10hp, there's a board capacitor, 3300uF, 80V that is starting to bulge a bit. I feel like I should replace it now, which looks like a bit of work to get the board off and all that but I've done it before for guitar amplifiers and such so I think I could manage. But at the same time I feel like with around 10yrs... maybe I shouldn't screw with any of it at all for risk of jinxing it... what would you do?
Other odd bit, the Line filter capacitors on my 10hp are 20uf, but manual calls for 40uF? maybe it got changed in a slight redesign after mine?
anyhow, I'll email them to see and also probably order these capacitors right from them since google isn't finding this part#.
thanks
thanks
