coppexil
- Dec 11, 2017
- Texas, USA
I'm brand new to posting here, but I've been reading PM for awhile now. Thanks for sharing all your experience, and wisdom. I have a few questions related to this xfmr, phase conversion, etc, but I'll keep each one in a separate thread, as board sticky says.
I'm getting my new shop space ready for a Speedio, and generating 3-phase via a phase perfect converter. Utility power hovers around 240VAC, and Brother app engineer told me that it would be preferred to have voltage centered around 208VAC or so, even though the Speedio can accommodate up to 245. So, a buck autotransformer with 16/32V windings seems like it should do the trick. (Side-note: I'm aware that they need to be sized based only on the BB voltage, not the overall voltage). PP recommended the (made-in-USA) Dongan brand. Spoke to app guy there who suggested I buck the single phase, prior to 3-ph conversion at the PP. That was my plan, until I read a few folks on here talking about using dual BB xfmrs after conversion to modify the 3-ph power. Since PM guys generally do things for good reason, that made me want to better understand the pros and cons of each choice. Here's what comes to mind so far:
Buck 1-ph (before phase conversion):
1) Less expensive and easier to install (only need one BB xfmr)
2) Less flexibility in terms of different 3-ph voltages (only get 208VAC 3-ph, in my case)
Buck 3-ph (after phase conversion):
1) More expensive and harder to install (need two BB xfmrs, more complicated wiring)
2) More flexibility in terms of different 3-ph voltages (can access both 240VAC 3-ph and 208VAC 3-ph)
In my case, the flexibility of having multiple different 3-ph voltages is not particularly important. Am I missing any other pros? Eg, perhaps some benefits to power quality or the like? If not, or if they are not significant, I think I'll just continue to go ahead with the planned 1-ph buck.
Thanks so much for advice.
