Please I need help wiring Leeson motor to Furnas switch
Results 1 to 2 of 2
    May 2016
    Florida
    Default Please I need help wiring Leeson motor to Furnas switch
    Hello,
    I recently bought an Atlas Colchester lathe that was a basket case.
    It has a Leeson motor (cat# 100956.00, model# C4C17FBA).
    The motor has 6 wire leads labeled: T1, T2, T3, T4, T5, T8
    For low volt (I assume 110AC):
    CCW L1: T1, T3, T8 L2: T2, T4, T5
    CW L1: T1, T3, T5 L2: T2, T4, T8
    The Drum Switch is a Furnas A-14/A14. It is a 3 position switch with Off in Center position with Forward & Reverse on opposing sides.
    On the bottom of the switch there are 6 terminals A, 1, 2 & B, 3, 4.
    The switch has been wired where: white to A, none to 1, gray to 2, black to B, green to 3, red to 4.
    The internal connections wiring diagram reads:
    Forward: A, 1, 2 B, 3, 4
    Reverse: A, 1, 4 B, 2, 3
    Any help is appreciate but remember you're communicating with the electronics class idiot!
    Keep it simple, PLEASE!
    If in this posting I made any faux pas, please accept my apologies.
    Thank you. Lou
    Here are the motor specs:
    Catalog No 100956.00 Model C4C17FB4G
    Product type AC MOTOR Stock Stock
    Description 1/2HP..1725RPM.48.TEFC.115/208-230V.1PH.60HZ.CONT.NOT.40C.1.15SF.RIGID.GENERAL PURPOSE.C4C17FB4G
    Information shown is for current motor's design View Outline | View Connection
    Engineering Data
    Volts 115 Volts 208-230 Volts
    F.L. Amps 8 F.L. Amps 3.8-4 F.L. Amps
    S. F Amps 8.4 S. F Amps 4.1-4.2 S. F Amps
    RPM 1800 Hertz 60
    HP 1/2 Duty CONTINUOUS TYPE CF
    KW 0.37
    Frame 48 Serv. Factor 1.15 Phase 1
    Max Amb 40 Design O Code L
    Insul Class F Protection NOT Therm.Prot.
    Eff 100% 66 Eff 75% PF 61
    UL Y-(LEESON UL REC) CSA Yes Bearing OPE 6203
    CC Number CE Bearing PE 6203
    Load Type Inverter Type NONE Speed Range NONE
    Jul 2014
    MI USA
    746
    189
    311
    The diagram to use is listed on your drum switch schematic. Use the one that says "Condenser Motor 6 Leads 110V"
    The start winding leads that are not labeled in the diagram are T5 & T8 on your motor. You can connect them (T5 & T8) either way. Swap them around to change direction rotation if desired.
    SAF Ω
