kroll
- May 26, 2013
- Porter,Texas
I did not know if this is the right spot or not but reading other post here,maybe it is.
Guys I pick up a motor that has no capacitor or tag on the motor saying what size hp it is or how to wire for 120/240 volts.I was told that it and the drum switch came off a lathe that it was wired for 240v single phase and guessing that the rpm is 1725.The motor leads or as follows P1,P2,T2,T3,T4,T5,T8,I don't understand why its missing T1 nor P1 and P2then jumps to T8.Now the drum switch is Rev/Stp/Fwd and tag on the left side 1,3,5 on the right 2,4,6.In Rev 1,2 is made 3,4 is made and 5,6 is made.Fwd 1,3 is made 2,4 is made 5,6 is made, if any of this makes since.I have look at several wiring diagrams but have not come across one that shows these type of motor leads.Any help with directions or links to somewhere is much appreciated---kroll
