MT6
- Dec 25, 2004
- Northern Colorado
I bought one of the Chinese 4 HP inverters off of Ebay for $126.
Hooked it up to my Bader Space saver grinder. 5 HP 3 phase motor on it.
Programmed the parameters for Freq, output voltage, current, and so on.
Powered it up and thought I should have lots of torque now.
I'm running it off of 240 volt single phase.
I could easily slow the belt down, dang!
Checked all the parameters again but didn't find anything wrong.
The bus voltage is around 357 volts, only drops a couple when I load the motor.
The output voltage can be monitored by toggling through the selections to the small u.
It only reads 79 volts. Thats got to be a problem.
That is with the output voltage programmed to 255.
Contacted the vendor and sent him the entire parameter list, he said it was a bad VFD.
Sent a new one to me.
This new one only reads 45 volts on the output and is very easy to stall.
Even with the motor disconnected the voltages reads the same.
I hooked up my Hitachi 2 HP inverter to the motor and it ran great, couldn't stall it.
Anyone else had any experience with these?
Is there some hidden parameter that says divide selected output voltage by some random number?
MT6
MT6
