toolmaster1d
- Nov 24, 2017
Thank you for looking.
I have the WJ200 VFD connected directly to the motor leads
Motor leads
Connected line 1 to leads 1 and 7
connected line 2 to leads 2 and 8
connected line 3 to leads 3 and 9
connected leads 4+5+6 together
VFD
T1 (U) connected to leads 1 and 7
T2 (V) connected connects to leads 2 and 8
T3 (W) connected to leads 3 and 9
Connected 220 power to VFD per manual 2 hots and ground
Turned on and started the programming for the power up test. Pushed the run button at the end and got nothing out of the motor.
Display lights up run and power
Looked at some u-tube videos and found some information.
Cleared the program from my first attempt and tried the one below from u-tube, still nothing out of the motor.
Factory reset B084 set to 02 then B180 to 01 and the VFD changed to D001
Made the following changes in this order
B037 to 00
B038 to 000
B012 changed to the amps rated on my motor 7.5
A001 to 002
A002 to 002
A003 to 60hz
A004 to 60hz
A082 to 200 volts
H004 to 4 poles
Same results.
I checked the lines with a voltage detector and only detected voltage coming in the VFD, no voltage in the lines feeding the motor out of the VFD.
I'm getting better at the navigation menu but have no experience setting up a VFD.
Any help would be great.
Thank you
Motor leads
VFD
B037 to 00
B038 to 000
A001 to 002
A002 to 002
A003 to 60hz
A004 to 60hz
A082 to 200 volts
H004 to 4 poles
Same results.
Thank you
