Hi there.
I'm thinking about installing a vfd in my shop to run a 10hp three phase motor on an old Mazak lathe I just got. I'll just point out right away that I am not a electrician. I understand the need to double the size of the vfd to handle the extra load of converting to three phase. At the risk of sounding like a dumb a.s.s. Could a person run the L1 & L2 to the input of the vfd as normal, but also run another dedicated wire with a dedicated breaker to L3? I realize that this wire would be the same phase as L1 or L2 but was wondering if this would reduce the load on the vfd.
Not to mention the price of a 20hp vfd it would be very close to maxing out the service on my shop.
Is there any other way around this? Can one run a smaller drive with the 10hp motor and just not use it to full load?
Also going to have to run a transformer. Is it ok to run the drive before the transformer or is it better to run it with the higher voltage? It would be nice to keep it at the 230 just gives me the option to run other equipment of different voltages if the need arises.
Also this not along term thing as I plan to be move to a bigger shop with three phase power in the next couple of years. So I would like to keep the cost down and or buy equipment that will be useful down the road.
Looking forward to hearing some input
Joe
Joe
