Sea Farmer
- Mar 25, 2006
- Cape Cod, Massachusetts
Cleaning up 3 old halogen desk lamps and noticed no internal wiring after the transformer.
All 3 are made in Italy, different designs and brand names, and fairly expensive. They all have 120-12v transformers, either in weighted bases or along the supply cord. The outputs from the transformer are carefully hidden from sight, but must be simply soldered onto the inside of the frames, and it appears the frames carry the current to the socket. There is no internal wiring within the frames that I can find.
Here's a pic of a very similar lamp to one of mine: http://img0109.popscreencdn.com/160268712_ledu---concentrolite-halogen-desk-lamp-tiered-shade.jpg
The design has some obvious advantages, it allows the frames to be very thin and lightweight. My question is what is coming out of the transformer, and why is it safe to do this? If there is not an insulated wire running from the transformer to the bulb socket then we are handling the conductors when we move the lamp around. Is the current so low we don't get shocked?
