Domodude17
- Aug 14, 2017
I have a Weg CFW07 VFD. It is a 220v, single phase model which converts to 3 phase. The information on the VFD says it is rated for 2.6 amps, and the motor it will be running is a 220v 3 phase 1/2 hp motor. Anyways, on the circuit board in the VFD, there are 8 terminals. Terminal 1 is marked as the ground, and terminals 2 and 3 are marked line. I know this means the two hot lines coming from the wall. Terminals 4, 5, and 6 are marked "motor", and 8 and 9 are marked "BR" for brake. I dont intend on hooking up a brake at the moment, but i'm not totally sure how to hook up the motor. Does it matter which wire from the motor is hooked up to which terminal? Or does it not matter because they are all one part of the wave function? If it matters, the motor is marked as dual voltage. Thank you!
