Sorry for the long title, I try to provide enough info so people don't waste their time opening posts to see what's in it.
Anyways,
I would like to know if their is really a big difference between a P-A-M RPC and a good homebuilt RPC using a standard motor.
Below are the specifics on why Phase-a-matic thinks their RPCs are so good.
Are they full of it, or just trying to justify the cost?
I have a Phase-A-Matic rotary converter, according to Phase-A-Matic), it's built on a baldor motor designed as a rotary phase converter, there are no start capacitors, relays or contactors with connections which can come loose or arc.
Therefore they claim their failure rate is zero.
P-A-M's MTBF = "Failure rate (MTBF) is so low it's almost impossible to determine. We find that within the first 12 months approximately 1 in 150 might have a problem, and usually within a few weeks or months. After the first 12 months, it might be one or less in 5,000 over a 30 year period."
Thank you for the info,
Steve
Anyways,
Steve
