Excitable Boy
Hot Rolled
- Aug 23, 2003
- Simi Valley, CA
I got a NOS Leeson 2hp 3 phase motor and a Toshiba 2hp rated VFD. The VFD is specified to run on 230V single phase input and provide 7.5amps variable frequency output.
I'm fine with low voltage stuff, but an a little paranoid about working with high voltage (read deadly) electricity, plus I don't want to damage anything.
The motor has ten wires coming out of it. I got a basic wiring diagram (which I ould email to anyone interested in looking at it. The motor is rated 230V or 460V. On the diagram it indicatesthat for high voltage L1 (electrical leg I think)goes to T1, L2 to T2 and L3 to T3 and then notes to join and insulate three additional pairs of wires. For low voltage (my application), it indicates L1 to T1,T7, L2 to T2,T8 and L3 to T3,T9 and then join and insulate T4,T5,T6.
Does this mean to wire two wires as specified to each of the three output terminals on the VFD and then twist the other three together with a wire nut? What's the 10th wire for? Ground?
The wires coming out of the motor are all steel stranded. Is #10 solid core a good choice to use between the VFD and motor?
Anyone in the neighborhood want to make a couple quick bucks? (this sstuff makes my skin crawl).
It will be fed from a dedicated 20 amp circuit. Is that enough? Also, how large an input cable do I need from the wall to the VFD?
