cinematechnic
Cast Iron
- Apr 11, 2005
- Walnut Creek, CA
Hey guys, it's been a while...
It looks like I may be moving into a new space and setting up my machine (Schaublin 102N) again after another (damned) year in storage.
Unfortunately the new location does not have 3 Phase power. Fortunately I do still have my RPC (Arco Roto-Phase MG). This unit was quite noisy in its stock self-starting configuration.
I am very grateful for the quality of information on this forum. Back in 2009 I inexpensively modified it to a capacitor/relay start and balanced the phases, using the valuable information from this forum. That quieted the idler substantially but it is still not quiet.
In my new location, there will be a retail showroom (for cine cameras and lenses) in the same building. So I want to be able to limit the noise of my machines. The Schaublin is belt driven and relatively quiet when running on true 3 Ph power. I also don't take heavy cuts since I don't do production work. So it's just the RPC noise I'm concerned with.
The Schaublin is a 380V machine with an internal step-up transformer. This greatly complicates the easy path of using a VFD with single phase input. Replacing the motor is also not a viable option due to the motor's unique configuration.
I know a digital phase converter like Phase Perfect would be the ideal solution, but that is out of reach for a good while due to cost.
Does anyone have any suggestions about quieting / muffling a RPC?
I had thought of building a box around it with sound absorbing material. My main concern is heat buildup. The box could be ventilated, but that may allow some of the sound energy to escape.
Any suggestions / links would be appreciated.
