viper
Titanium
- May 18, 2007
- nowhereville
One of the common controls today is an "on demand" system that simply throttle are vary the pump speed depending on demand. They are simply controlled with a pressure transducer. As the pressure drops, the pump controller commands a higher speed to the pump to maintain pressure.
Just curious how a guy might set this up with a VFD instead of a standard pump controller which I find to be nothing more than a stripped down VFD. However, there seems to be a slight amount of PLC type calculations here regarding the pressure transducer. It would easier and cheaper to just run a more standard VFD if possible.
I am also kind of wondering about a slight over speed of the pump system. Seeing this load as a variable torque application, it might not be a good idea to try and overspeed the pump for fear of needing more torque than the motor can safely provide.
