conant
Stainless
- May 13, 2013
- Shasta County, Ca. USA
How do I assure that 2 Rotary convertors ran in parralel have all phases matched?
Once or assuming the second rotary phase converter is running what is the difference in connecting it in parallel to the first converter as compared to adding another idler motor?...Having two RPCs both trying to generate a third phase, is somewhat of an Invitation of Electrical Disaster. (IED).
As I see it the second rotary converter is simply another idler although with it's own starting system; which once running would then be out of the picture.
Because the second rotary converter is developing it's own 'generated' leg which is not necessarily going to have the same phase displacement of another unit...
Since you have TWO sources of incoming power, you'll have two rotary converters, and where the phases don't match, you'll have current flow to TRY to make the voltages equal.
Yep, sounds like a good simple plan.
You may find the lathe starts fine on the 7.5HP RPC,
If not then adding the 5HP idler with it's own on off switch is a great idea and the combo should easily start the lathe. You'd first start the converter, start the 5HP idler, start the lathe, and if you wanted to then turn off the 5hp idler, or leave it running.
If the converters are in parallel they would/should be fed from the same source of power, if this the case are the troubles you mention still an issue? In what situation/shop and for what reason could you have 2 converters fed from different sources and still be in parallel, excluding the use of a generator?
Notice
