ronr
- Jun 5, 2004
- Northern Michigan
I recently purchased a small radial drill that has 440v only motors. I run my three phase stuff on a 240v RPC. I plan to use a 4 kva three phase step down transformer in reverse to run it. I wired it up and it seemed to run ok. When I hooked it up I used the terminals that had been used in its original application as a 480 to 240 step down. The 240 fed into X1, X2 and X3 the 480 output was from the three “2” terminals.
Each coil has six leads coming from it, three go to the primary terminals and are marked 1, 2 and 3. one goes to the secondary terminals and is marked X1 or X2 or X3. One lead from each coil is soldered together and the last three (one from each coil) go to the two terminals marked HOXO. One lead goes to the first HOXO and the two others are paired together at the last HOXO. The two HOXO terminals are not connected together.
Shouldn't the three leads going to the HOXO terminals be ties together? Could someone please explain how this is wired internally and is it set up right for my purpose?
