RonRock
- Mar 18, 2012
- Underwood, IA
The plan that I am following is for a 10 HP RPC. I am building a 7.5HP. The plan has 2 contactors one on the line in side and one on the 3 phase side controlling the start caps. The plan calls for the line in contactor to be rated @ 60A inductive load, and the second rated @ 40A inductive load. I should add that they are both 3 pole with 24V coil. The first also has 1 aux contact that goes to the remote switch terminals.
So since my RPC is 7.5HP am I correct that the contactors should be sized for my motor that draws 21.6A? Such as a 25A contactor. Do I need a larger one on the first that also controls the Aux contact and potential relay?
