stelradCoal
- Feb 8, 2009
- Winsted, CT
I'm in the process of putting together a RPC. I picked up a 10HP 3phase motor and put together a very quick and dirty RPC to see if I could get the RPC motor spining and see if I could get another motor running. I have been able to successfully do that, but now I need to put something together that is a bit more permanent and safer.
I have been doing a fair amount of reading and am trying to determine what I want to do while putting this RPC together, if I want a pony start RPC or cap start.
My current situation is I have a seperate two car garage which the 3 phase machines are in, its about 150-200' from the main house. Last year I dug a trench and ran a conduit between the two buildings and then ran wire between the main 200AMP panel in the house to a 100AMP panel in the garage. I can't remember what the wire size was that I pulled, but I do remember it was sufficent for 100AMP sub panel work.
My intention is to run #6 wire to a remote cabinate which will be the connection center for the 3phase RPC from a 60 AMP breaker in the sub-panel. I would like to mount the RPC motor outside in a doghouse or up in the attic of the garage in order to minimize noise, but this remote mounting makes pony starting a bit more difficult. My other concern is the current inrush when a 10HP RPC is started with caps. I understand you should have between 50-100uf of capacitance per HP so I am looking at 500-1000uf. How much inrush current would that cause? Is it likely I am going to cause light flicker/dimming in the garage, main house, neighboorhood? Will I be poping circut breakers regularly?
I'm probably going to put the RPC together in phases, a simple push button start to begin with a more automated system later as I aquire parts etc... Any downside to a plan like this?
Thanks in advance for the advice.
Jay
Jay
