Hi guys,
Just have to start by saying thanks - this particular forum is where I got 99% of my info and inspiration when I went to build my 10hp RPC. The lathe it powers is a 7.5 HP Romi T17.
Everything is working pretty well, the idler motor starts on about 1000uf (10 x 100uf in parallel) and the voltage is nicely balanced using smaller run caps (65uf and 100uf). I'm using a Steveco 90-66 to switch in the starting caps, which is probably more than the contacts are rated at but it works fine. It starts quickly, runs smooth and cuts out at exactly the right moment.
However... After running a couple minutes, at 1-2 minute intervals I hear a clunk - the starting circuit re-engages for a split second, there's a spark from the Steveco as it immediately disengages, then it runs fine again for another couple minutes. I think the clunk is mainly the motor being suddenly slowed by the start caps, then as quickly speeding up again when they're gone.
What causes this? Is this something you have run into before? I can post the circuit specifics if needed, but it's a pretty standard design. I don't have bleed resistors on the start caps yet, if that makes a difference.
Thanks in advance!
Thanks in advance!
