Psychbiker
- Aug 15, 2016
Hi Guys!
I'm dying to get this 16" planer up and running. It's a 5hp 16" old powermatic planer.
I bought a huywang 5hp rated VFD but I'm not confident it will work. My dad dropped off a 15hp baldor 3 phase motor few weeks ago. Plan is turn that into a rotary phase converter.
The more I research, the more questions and I have.
#1 - I have a 100amp single phase service panel. Is this enough to run the 15hp baldor 3 phase motor? The motor is missing the nameplate, I have no clue on stats aside from it being an old, likely 30 year old, 15hp 3 phase motor.
#2 What is the likely amp draw of the 15hp motor when on AND the planer being used?
I'd prefer the RPC route because in the wiring process, we'd add a couple 220v plugs and breaker box to plug other 3 phase machines into.
#3 Is wiring the VFD easy to do? The directions and posts online make it sound tough cuz the manual is terrible. If wiring the VFD, I'd like to put a male plug on in and plug it in when ready to use the planer and unplug it when I need the outlet for other tools.
I thought about finding a 5hp single phase motor but they are $$$ and the mount and shaft size have to match and it also messes with the original switch.
