I've been searching the forums all day hoping not to bother everyone with a question, but I've hit all the dead ends I can see and don't know where to go next
I'm using this VFD:
KNC-VFD-CV20-1S-0002G
And this motor:
Leeson 192017.00
I'm unsure about many things, so I'll just load you with what I think I know and what I know I don't know.
The Problem:
I can power on the VFD, but when I set a frequency the motor makes a high pitch noise and the breaker trips.
Wiring the VFD:
The VFD is designed for a single-phase 120v input. From the unclear users manual, it seems L/N are L1/L2. I know some 120v VFDs use L3 as N, but this unit will only power on with hot at L1 and neutral at L2 (I checked the input voltage with a multimeter to be sure that wasn't the issue)
Wiring the motor:
I followed and triple checked the wiring diagram on the motor box for low-voltage. (Attached)
VFD settings:
I thought the issue maybe in the factory settings for the VFD being mostly 50hz. I changed all the 50hz defaults to 60hz and increased the max output voltage to the proper range for the motor low-voltage inputs.
I'm attaching images. Hopefully something jumps out.
I'm using this VFD:
And this motor:
Leeson 192017.00
The Problem:
Wiring the VFD:
Wiring the motor:
VFD settings:
