I am looking at powering a 3phase, 2hp Harrison lathe with a VFD connected to a single phase source.
Probably going with a drive from Automation Direct.
Specs for their GS2 series drives; https://www.automationdirect.com/adc/Shopping/Catalog/Drives/GS2_(115_-z-_230_-z-_460_-z-_575_VAC_V-z-Hz_Control)/GS2_Drive_Units_(115_-z-_230_-z-_460_-z-_575_VAC)/GS2-22P0
Next size up in the GS2 line is a 3hp version for about $60 more
In the interest of keeping costs down, I am considered their GS1 series drives, but I have serious reservations.
https://www.automationdirect.com/adc/Shopping/Catalog/Drives/GS1_(120_-z-_230_VAC_V-z-Hz_Control)/GS1_Drive_Units_(120_-z-_230_VAC)/GS1-22P0
I anticipate setting the VFD for 60hz and adjusting the speed with the lathe gears.
But, will I need to use the VFD for the start stop function, or can I still use the lathe switches?
Thoughts?
That leads me to believe that the de-rating may not be required. However, other research I have done says that since only a portion of the diodes are driven with a single phase source. Therefore, the derating is recommended.Number of Phases 1-phase and 3-phase
Horsepower By Phase 2hp with 3-phase and 1-phase input
That one looks like it is not suited for the application.Number of Phases 3-phase
Horsepower By Phase 2hp with 3-phase input
Thoughts?
