Hello All, I am a woodworker and new to the site, but this seems to be the place to go when you have transformer and phase converter questions! I have a new tablesaw that I am trying to get running which has a 5hp 3 phase direct drive motor that draws 6.4 FLA and would like to run it on single phase 220v.
I've read ToolNut's suggestion to run 440 3 phase motors on single phase through a transformer/vfd and would like to go this route utilizing a general purpose Hevi-Duti 10kva single phase 440/220 step down transformer that I would like to back feed, the 440 of which will go to a 10 HP 440v GE AF-300P11 VFD.
My questions are, when wiring a single phase transformer in reverse, how many amps will the transformer be pulling? Also, do the grounding issues from back feeding transformers only apply to three phase delta-wye units or all units including single phase? How do I ground this properly?
I understand the calculation for the "new" primary in my case to be: 10kva/220v = 45.45A*125% overcurrent protection = 56.81A, but have also read that you should increase the overcurrent protection by 250% to compensate for the higher inrush! Any help would be greatly appreciated, thanks!
