building a multi outlet extension with so. Although it shouldn't, I'm sure at some point it will get wet outside. I'd like to protect the stranded so from corrosion so thinking heat shrink fork/ring terminals or solder to solid wire w/ heat shrink and put the solid wire under outlet screws. (Either way maybe silicone grease on the screws?) Thoughts on which of those two options would be better or other ideas would be areciated. Thanks!
