Motorsports-X
Hot Rolled
- Nov 22, 2014
- Texas
I assume there might be some folks in here than know a bit about power generation. I would like to put together a batteryless solar array. Phase one, 6kw worth of panels, which will constantly provide on demand power to the home and grid. Phase two is storage. The only two technologies I can find that I think are really feasible for long term are flywheels and hydrogen. Hydrogen is cool but requires massive outlay of capital, and specialized equipment.
The flywheel however, is about as simple as it gets. The main reason I want to do this with rotary motion is the simplicity of connecting a new source to the input should should you lose your panels... Or maybe you want to supplement with wind... Anyways..
On the motor side.. Basically speaking, your going to spin the flywheel at varying speeds... How do you get the ac generator to put out the 60hz we all know and love (assuming you're driving the flywheel with DC motor) secondly... Once the sun sets and the flywheel is spinning faster than the DC voltage is driving the drive motor... How would you continue to use the power coming from the panels (again without batteries)
Lastly.. On the flywheel. Would using maybe centrifugal weights to maintain constant speed be a good idea?
I want to do a YouTube series building this. I've seen the high speed beacon fly wheels but those are out of reach
