jermfab
Cast Iron
- Jul 25, 2013
- atlanta, ga
Not sure if this is the right place for this post, feel free to move if necessary.
I purchased a Speedaire Compressor off Craigslist last night. It's an older model, but has similar specs to their current, flagship models:
Three phase, 7.5 horsepower, 24.3 CFM, upright compressor with an 80 gallon tank. The motor is dual voltage, 208-240/480. I believe this model is a 1ed63, but I'm having difficulty verifying that. The main difference between this model and current models seems to be motor efficiency. The specs on the current models list lower FLA values for the same output. Current units operate at 19 or so amps while this motor lists 21.6 amps to start.
Unfortunately I was unable to test the unit prior to purchase as three phase power wasn't available. I got the machine to my shop and plugged it in to a 20 Amp circuit. The contactor contacted and the motor spun, but much slower than the listed 1750 RPM. Check the motor connections and determined the wiring was for 480v, not 208. Rewire the connections and now the motor spins at the proper RPM, but will only operate if I manually hold the contactor down. Aside from that the operation of the machine is as it should. It compresses air and the pressure switch does shut off the unit.
Is there a possibility that running the motor on too low of voltage damaged either the motor starting relay or contactor?
Do I need to change the thermal units to reflect the difference in ampacity from 208 to 480?
The motor starter in this unit is a Furnas
Cat no 16BF35AGASY
PN P14178A
Again, a rudimentary google search yields very little other than specs on this specific unit. I imagine it too has been superseded by a more current unit.
Anyhow, I'd rather not buy another motor starter if this one can be salvaged, but will gladly accept any advice as to testing and diagnosing the problem.
Thanks all
Jeremy
Cat no 16BF35AGASY
PN P14178A
Thanks all
Jeremy
