SRDC
- Jul 2, 2014
- Texas, USA
We are updating a Mazak VMC (VQC 15/40), and have a 7.5HP Mitsubishi spindle motor - 5.5kW / 32A max. A 1024 ppr shaft encoder is mounted on the spindle.
The current spindle controller is a Mits Freqrol FR-SE 5.5kW, and handles orienting for toolchange, and closes the speed loop (these components were all part of the original Meldas/Mazatrol M2 control system). The spindle controller is currently non-functional due to a power supply with a fairly significant repair cost from Mitsubishi.
We are looking at replacing with a Hitachi VFD - either a WJ200 or a SJ700 series - both are 'sensorless vector drives'.
I've spent a fair amount of time digging through the forum, but have a few questions I was hoping some of you might be able to help with:
1) Is there a problem with swapping a 'spindle controller' for a VFD? It seems basically the same thing, but I'm not sure if I'm missing little details
2) The output of the Hitachi SJ700 7.5HP VFD I'm looking at is 230V/25A. The motor is 200V/32A... Based on some discussion I saw by MotionGuru, it appears I would need to upgrade to a 10HP VFD 230V/35A to get full motor capacity?
3) Any idea on line chokes / line reactors - how do I know whether I should put them on the VFD input? output? We're planning on mounting the VFD in the cabinet on the machine, if that makes a difference.
4) I have the option of buying an encoder feedback card for the VFD ... is there any benefit (besides config ease) to allowing the drive to handle the velocity loop and spindle orient instead of (saving money) by allowing the new control to close the velocity loop & handle orientation (LinuxCNC)? Stability? Speed of response?
5) Any gotchas or anything else I'm not thinking of or should be aware of?
Thanks in advance!
Thanks in advance!
