Am running a 7.5 HP, 3ph. motor with 8hp static converter and blew my 30 amp fuse(motor safety fuse)for the 2nd time. this was after motor was running, both times. now after 2nd time i cant get motor to start now.it rattles & keeps blowing fuses. This motor powers a Hyd piston pump running at only 500 to 1000psi, so there is no heavy load on motor. I also hooked motor up direct to 3 phase & it run fine but I was bypassing fuses. My Question is if the static conv is the problem starting,what made fuses blow after it was running when conv is no longer doing anything? Motor amps is 21 & I have 30 amp fuses. Any help would be appreciated.
