JohnnyB64
- Feb 15, 2010
- Charlotte, NC USA
Circuit / motor protection on 3PH motor with VFD
Connecting 2HP 240V 3PH motor to our 240V 1PH supply with an Automation Direct VFD rated 2HP 1 or 3PH. Using an existing 50A 240V 2 pole breaker with a welding receptacle we had already. Temporarily, I ran a #6-3 cord over to the panel until I can run a conduit overhead. As soon as the cord hits the panel, I switch to (3) #12 AWG THHN wires to the input on the drive, then (4) [T1, T2, T3 + GND] to the motor. With this setup the motor and the branch feeders are woefully unprotected, correct? Not knowing, my impulse is to add a 3-pole fuse block between the drive and the motor. Is this correct? Are you supposed to use special (like an I sq T, fast blow) fuse that will protect the drive better than a regular motor fuse? The Automation Direct catalog seemed to suggest the fusing went upstream of the drive (?) on the line side. I've looked at other (amateur like me) wired setups and see no fuses at all. There are tons of single phase motors in our shop with no protection of their own, but this lathe (Southbend with Louis Allis 2-speed 2-winding motor) originally had a really nice setup with Furnas starters / heater overloads. What's correct here? Thanks, John
