I am running a 2 HP Lathe from the Teco N3 control pad, I would like to add external Forward Reverse Stop using the original momentary contact pushbuttons
I have tried to read previous threads and understand I can do the start/stop using 3 wire control setting using terminals S1,S2,S3, but this will not use the Reverse button.
Could I use the S4 terminal set for the Reverse function? This would be in parallel with the Forward (or start) switch
I'd like to stick with these switches since they are labeled and fit the existing box- if no go I'll just revert to the 3 wire control with toggle switches.
I'm looking at page 4-55 in the manual, trying to find how momentary pushbuttons are used- what seals the signal when the button is pushed?
Final question:
Best mode to use Common(NPN) or 24V (PNP)? Why?
Thanks for the help.
Final question:
