DanMc77
- Aug 23, 2017
- Holden, MA
Hello!
I installed a Teco N3 VFD on a South Bend 13" lathe with a 2 HP 3 phase motor. This couldn't have been much easier. Bring in 220v single phase, wire the motor to the VFD, run Auto-Tune and it runs very nicely. I checked the settings it came up with and it's pretty much what the motor label shows.
Now I'm wondering: Just for kicks I set the max frequency to 100 Hz and gave the machine a spin with no load. The motor is spec'd for 60 Hz and it seems to run fine at 100 Hz, just faster.
Are there limits for "overclocking" a motor and running faster than the rated frequency? If 100 Hz is OK, what about 120 (double-speed). What happens at higher frequencies? I would expect that at higher frequencies, it's like putting a heavier load on the motor and it will generate more heat.
Anybody have experience doing this?
