lin842
- Sep 27, 2008
- Richmond Va
Is there any way to change a 3 phase motor so that it can be run on single phase. I mean can you rewire the motor or do you have to go the phase converter route?
I have a 4000 lb lift table and it has a three phase motor on it and I found another power unit that was supposed to have a single phase motor but when it came to the door it was three phase too. Now I have two hydraulic units and can't use either one. I thought about just buying another motor but both these motors are 3500 rpm motors and they are hard to come by from what I have seen. Can they be rewired to run on 220V.
