toolmaster1d
- Nov 24, 2017
Greetings, I'm trying to purchase and connect a VFD to my Toolmaster1D.
Here is the data plate information.
G.E. model (5k180dj280)
2 (ab) horsepower 3 phase
Volts 208 – 220 – 440
Amps 6/3//7.2/3.6
Cycles 60/50
RPM 1730 // 1440
Deg C Rise 40 // 50
Service factor 1.2//1
Time rating cont.
Nema design B
Frame 180Y
Type K
Code K
I verified the wires are connected to be ran on 220.
The plan is to run 220 single phase into the VFD
I can think of 3 inputs for the VFD "hopefully this is the correct term"
On / Off
CW / CCW
Deceleration , my spindle brake is missing off my Mill.
Hopefully I can use the switches on the Mill to control these inputs.
Not too concerned about controlling RPM since it can be adjusted by turning a lever on the Toolmaster.
Please feel make suggestion or corrections.
Looking for a model and brand recommendations for a reliable VFD.
I would also hope the recommended VFD comes with a great set us instructions.
Thank you!
Amps 6/3//7.2/3.6
Cycles 60/50
RPM 1730 // 1440
Deg C Rise 40 // 50
Time rating cont.
Nema design B
Frame 180Y
Type K
Code K
On / Off
CW / CCW
Thank you!
