What K Factor is normally recommended, if any, for a transformer that will run Cnc's, possibly 2 at the same time. I never heard of it before, I kinda doubt anyone even looks at it when installing one on a new machine?
I ran into that option while pricing out features from a transformer manufacturer in Canada. Standard units are K-1. Then K-4($200),K-9($420),K-13($590),K-20($870) option(Cad$).
The only 2 mention I found of K-factor while trying to find an answer online called for a K-20 for VFD drives/CNC's.
The main issue with harmonics seemed to be transformer overheat. I'm currently looking at 45Kva units, expecting it to be eventually loaded to maybe 60-70% capacity when I get a 30hp PP and run 2 machines at once. How much does regen dump heat into a transformer? Perhaps that 30% left up top is not enough to keep it cool if only a K-1 ? I'll also have AC in this new shop, 20°C and air flow. I want to do this only once and don't mind paying a bit, just want to make sure I get the right thing, without pissing away too much $ for nothing either.
thanks
thanks
