John Allan
- Jan 29, 2011
- North Central Arkansas
Troubleshooting My Phase Converter
Two weeks ago my home made 15 year old, 7 ½ HP, phase converter died. As I tried to start it, he motor just hummed. After looking I found the starter overload tripped and a 3 amp fuse for the control circuit blow. Resetting the overload and replacing the fuse did not solve the problem.
I took the starter (AB 505 Size 1) out and put in all new contacts, as they were heavily burned. No joy. I then removed both the start caps and the balance caps from the circuit. Now I wired direct out of the starter to the motor. Tried to start with a rope, but still just humming.
While the motor was spinning from the rope, and just humming, I had an amprobe on the inputs to make sure that both legs were getting current. First one then the other looked to pull 60 amps for a second or so.
I also took the motor to a local rewind shop. It was checked for grounds with a megger, ohms on each leg checked, and finally started up on 3 phase. The motor started and ran smooth and quiet. I feel that things point to the motor, but I saw the thing run. Guys I am stumped.
John
John
