Hopefuldave
Cast Iron
- Apr 1, 2010
- Surrey, England
I saw an interesting transformerless 240 - 415v convertor diagram at http://www.mig-welding.co.uk/forum/threads/rotary-phase-converter-plans.32135/#post-350783, and I'm thinking I may try this for my shop, but 240-Delta/415-star motors over 4HP/3KW are rare as rocking-horse droppings in the UK: I've also seen RPCs with two or more motors (where the first acts as RPC to get the second rotating) - presuming I can put enough interlocks in to prevent the motors running at different voltages (one star, the other delta) and tune each with its own balancing capacitors, am I going to run into Big Problems? My assumption is that the motors won't need to be mechanically linked, although that could make the second draw a lot less current when first powered up?
An example of this convertor's shown at 23 Volts 1 phase to 4 Volts 3 phase rotary converter - YouTube - it seems to work, at least a single-motor version...
Any thoughts?
Dave H. (the other one)
Any thoughts?
