Greetings all! We have a large sheet metal roller we use in aircraft restoration that recently started sticking in forward. After going through the drum switch I then found the culprit to be the reversing contactor for the roller motor.
Disassembling and cleaning helped for a while but it soon went back to sticking so the hunt was on for a replacement. A conversation with a support engineer at Square D led to the purchase of a new equivalent reversing contactor, the 8702SCO8V02S which I installed and began wiring.
Most of the connections to the new unit are pretty straightforward, like the motor and control wiring, but the remaining connections for the coils and such aren't as clear. I'm an aircraft mechanic with enough other skills to be hazardous but know when to stop and start asking questions. Has anyone here performed a similar upgrade or perhaps know of some helpful resources I've been unable to discover?
Thanks for any information!
- Joe
- Joe
