I will be purchasing a new 7.5 hp two stage air compressor. It will be used around a mostly automotive shop setting. Mostly being used with a good sized sand blast cabinet, usually they require cfm in the high teens.
I have used a 5 hp compressor before, but just could just not keep up. Unless you like running it 100 percent of the time for hours at a time.
So, my question is 71/2 hp compressors come in either single phase set ups or three phase set ups. With the three phase I would need to purchase something like an American Rotary for around 1200 dollars.
Is there any advantage in using the phase converter and three phase air compressor, over the single phase air compressor?
Any savings in efficiency, electricity cost, etc.?
There is a possibility of more three phase equipment coming later, but each machine will be used one at a time.
Also noticed that Quincy air compressors, while a few hundred more, are made in U.S.A. if you believe they are a good choice, I would prefer to buy American.
Thanks Todd
Thanks Todd
