Machinery_E
Titanium
- Aug 19, 2004
- Ohio, USA
I have a hi-pot tester, and need to test the insulation on some cables that are used on 230 Volts to see if they are safe to use. The tester is able to use lower voltages like a megger.
On the tester, it measures the current leakage in micro-amps. In playing around with it, testing conductors, applying 1KV for about a minute results in about 2 microamps draw being shown on the meter. The current starts dropping ever so slightly towards the end of the minute period. On another conductor, the scale barely moves off zero amps.
How does one use the hi-pot tester to determine insulation condition? Is there a chart that shows acceptable amount of current leakage in relation to applied voltage? Or do I need to look at the current draw stopping/dropping instead of increasing as a determination that the insulation is in good condition?
