Vernon Tuck
Stainless
- Oct 26, 2008
- Brenham, Texas
Guys,
I hope to soon get back to my primitive bare bones RPC project.
I have a 7 1/2HP low speed (1155RPM) 3 phase motor currently fitted with new bearings and reconfigured to 230V.
I am modestly self-confident with single phase residential wiring but have no real experience with three phase.
For the moment I just want to see the motor run. I am aware that there are three motor power inputs and that these are labeled T1, T2, and T3.
As far as I know the motor is designed to run clockwise looking at the motor shaft end. I am aware that a 3 phase motor, when powered by 3 phase, can be made to spin in either direction by simply transposing any two of the motor feeds.
But what about when you power it from single phase?
Is there a "standard" or "proper" way to make the connection? In other words, should one single phase hot go to T1, the other to T2? or T3? Or whatever? And another related question: Between T1, T2, and T3, is there a "standard" or "proper" or "best" (unsupplied) line to use as the wild leg?
If I spin the motor with a rope and then hit it with 230V at the appropriate amperage (I'm gonna start with a 50 amp single phase breaker) AND it's wired right my understanding is that it will spin on up and run.
But what happens if the rope start spins the motor in the wrong direction from which it's wired? Will it quickly stop? Keep spinning anyway? Go up in smoke?
I hope to use the motor to test run an old Gorton tracer mill. If everything starts and runs I hope to then build a more sophisticated 20HP unit.
Thanks for any help.
V
V
