I picked up an old vfd to experiment with at my local scrapper last week.I have been wanting to try a 3 phase unit on single phase power.I have handled several welders in my travel,and it is common for inverter arc welders to run on 1 or 3 phase by excluding one of the wires on 1 phase.So after studying the wiring diagram inside the cover of the vfd and reattaching the wires to the local 3k pot,hooked up the neccessary jumpers,and threw the switch.I had a 3hp motor for the test mule,the drive is a 5hp drive on 3 phase.Worked good,I was surprised.Now I have a question for you guys,if I use caps from each leg of the 230v single phase to the third terminal of my input rectifier can I regain the dc bus voltage that I have lost due to single phase operation.I am almost certain I have read that you are not supposed to do that,but it may have been on a manufacturers website.And if you ask them you shouldnt do anything that could keep you from buying a new drive.
