Nolan
- Dec 11, 2005
- Woodinville, Wa
My situation is simple. But the answer to remedy the situation ...... Well, I'll need some expert advise on this one.
I've got a Sharp 2412 VMC connected to a Phase Perfect DPC-20 digital phase converter. I also have 3 other small pieces of equipment, all connected to the concverter via a 100 amp 3 phase panel.
My problem is that my incoming 240V single phase is more like 245 volts. which normally would be a good thing. But in this case is causing me problems, due to the fact that the Sharp VMC is calling for 220 volts, and the factory says 245 is just too hot, and will eventually cause problems. Of courst the converter puts out what it takes in, voltage wise.
My questions:
First is it better to step it down prior to the phase converter with a single transformer or afterwards before the VMC. Forgetting the other machines for the moment, and forgetting for the moment, the cost issues. And then, am I correct in assuming that stepping down the 3 phase would be more expensive due to needing at least 2 and maybe 3 transformers ? But perhaps they would be smaller and thus cheaper ?
Also, is using Buck/Boost transformers the right approach or should I be looking for a regular transformer on the 3 phase side of this probem ?
And last but not least, and the most difficult for me.... Help in sizing.....
I've got 100 amp wire and breaker on the single phase side to the converter (rated at 88 FLA) and a 50 amp circuit out to the machine (rated 15KVA which I believe is 36 amps) soooooo WHat size transformers would be required in each scenario?
I also run into transformer type issues... ie.
Type M ??
Type L ??
Type LM ?
Thanks in advance
Nolan
My questions:
Type M ??
Type L ??
Type LM ?
Thanks in advance
Nolan
