Hi Guys i have an old mazak quick turn 10 with some spindle drive issues. Im considering replacing the drive and have some questions. This machine has a motor rated at 7.5kw, 165v and 40a. Replacement drives are going to be rated at 240 of course so it looks like i would have to move up to a 11kw drive to get the 40a that this motor needs right?
Heres the big concern, Im running off a 30hp phase converter so dont have a ton of power available. If i buy a 11kw drive and set amps right for my motor, will the drive draw more current or would it be the same as before? I realize the higher voltage will have the potential to provide more torque at higher speed which would mean more power, but lets say a low speed of maybe 1000 rpm. Will the new drive draw the same amps as before or more?
