Hello
I have researched VFDs on this forum but have some questions related to clarification.
I purchased a 3PH Table saw from a high school and want to run the motor from single phase 230 input. Below are the specs of the motor:
Hp: 2
RPM: 3450 / 2850
Volts: 208-220 / 440
Amps: 6.2 / 3.1
Cycle: 60 / 50
Question:
1) My research seems to indication that any VFD will work with single phase input, just need to compensate with 2x HP. But what about the other specs such as voltage In/Out?
Below is a VFD I have been considering buying used on flea bay. Would this be too large for my motor?
ABB ACS150-03U-08A8-4
5HP
400 - 480 VAC Input
480 VAC Output
8.8 Amps
Thank you!
Hp: 2
RPM: 3450 / 2850
Amps: 6.2 / 3.1
Cycle: 60 / 50
Question:
5HP
400 - 480 VAC Input
480 VAC Output
8.8 Amps
Thank you!
