I have a 13x40 optimum lathe. Im in the process of wiring in a vfd. One problem I've run across is getting the oprators green "run" light on the face of the machine to work with control circuit for vfd. The light is used to tell operator all safety's are correct and ready to spin.
The problem I've found is how to wire the light so it's functional? The vfd states not to use vfd 12v source to power external devices. I've been trying to think of a way but can't.
Another thing was the manual shows a couple wiring configurations. Two or three wire control circuit. They show using a two position rotary switch for forward and reverse control. My machine has two micro switches opposing each other on the apron for forward and reverse. I really want to keep this configuration just rewire switches. Should I be worried about anything using my existing switches with rf frequencies or anything like that. Read so much conflicting stuff the more I read seems the more confused I get.
