I have a 3hp 3 phase Baldor motor (1216w grinder) id like to run a VFD on. I have done some reading but some of it has confused me. Not sure if I need to look for a VFD that is rated for 6 hp or 3hp. Any help would be appreciated.
Jeff
Data plate reads.
3hp
3 phase
50/60 Hz
Volts 208-230/460
Amps 7.7-7.3/3.6
RPM 1500/1800
Power input would be 110v
Would this work?
Amazon.com: Konmison VFD Drive VFD 11 V 1.5KW 3HP VFD Inverter Variable Frequency Drive Inverter for Spindle Motor Speed Control (11 V 1.5kw VFD): Home Improvement
Jeff
Data plate reads.
3hp
3 phase
50/60 Hz
Volts 208-230/460
Amps 7.7-7.3/3.6
RPM 1500/1800
Would this work?
