I recently purchased a second hand AcraTurn 1340 engine lathe, essentially a different version of the Girzzly G0709. This lathe has a built in coolant pump that I assume to be a Single phase 110V pump (since I see the transformer in the electrical cabinet tapped for 110). Since the lathe is 3 phase, I'll be using a VFD to convert from single phase, but how do I handle the coolant pump? Since I want to be connecting the output of the VFD directly to the motor, how can I also run the coolant pump?
